Arias Pistons ????
72nismo
Car: 510 / G35 / Murano
Can anybody tell me what kind of Arias Pistons these are ??
Dish Top
Dome Top
s13drifter88
Car: 93 S13 Coupe CA18DET (Money pit)
1996 D21 Hardbody (Work truck/daily)
!993 Del Sol (Daily)
1987 Pontiac GTA (Drag project, other money pit)
1989 SOHC S13 Buzz Car
dish top
72nismo
Do u know if this are for turbo set ups?
s13drifter88
dome will generally yeild higher compression ratios. those pistons being dish topped probably maintain the stock compression ratio which will be turbo friendly
72nismo
In regards to this Arias Pistons any one here use them on there KA-T???
Can they be used to boost in the 18-20psi if u have the rest of the proper components??
Nissan KA24E 2.4L SOHC 12 valve 89-90 240SX
Stock Bore: 3.504, 89mm Stroke: 3.780 Rod Length: 6.496 Head cc: 62.0 Gasket: .045 Deck: .000
Bore: in / mm - 3.524 / 89.50
Compression Height - 1.340
Dome CC - 11.5
Compression Ratio w/stock head - 8.8
Gram Weight - 366
Part Number - 3520400
Required Ring Set -1515403524
Dish top Turbo/Nitrousish top Turbo/Nitrous
martins_240sx
Car: 1990 240sx hatch, 1975 280z, 2005 F150 fx4
Yes my sohc\/ has seen atleast 10 dyno passes at 27psi and a few at 30-32psi. also about 4months of your area 18psi before said psi's. there has been NO problems with my bottom end at all
arias pistons
sportsman rods
clevit bearings
arp everything
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
I ran them with eagle rods in my SR20 to 28psi on a GT30r and I will be using them in my KA-T. I've seen them make over 700whp in two KA-t's at over 40psi.
