ogden240 »
https://forums.nicoclub.com/ogden240-u52706.html
Sun Jan 21, 2007 8:34 pm
So I was prepping everything to put my new cams in, set it to TDC, marked the chain links, loosened the cam sprocket bolts, and as I was taking the bolt out of the exhaust cam the washer behind it decided to play pinball all the way down my motor! Great!!!!
So I shined a flashlight down there and my guess is either it's at the bottom of the timing chain or better yet sitting inside the oil pan?
What are my options? Pull the water pump and timing cover or pull the pan hoping it is in there?
Any help is appreciated. Thanks.
