Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Thu Oct 07, 2004 4:08 pm
sounds like you stripped it. best thing to do is to just pull up on the support bracket and see if the screw comes up with it. then you'll have to retap the hole. If that doesn't work, drilling will be your best bet.
In the future, don't get over zealous when tightening small bolts like that. I can safely say that I have learned my lesson quite a few times, and if the bolt seems small, you're best off using a 1/4" drive socket to take your torquing down a notch.
