argh i'm down on power!!
S14tat
Car: 2007 FX35
1994 Acura NSX
1996 Honda Accord coupe
1995 S14 KA-T *sold*
i just came back from the dyno. i just installed a Z32 MAF and i needed to get it retuned. i'm still running 9 psi, and i elimated my fan clutch. and to my surprise i'm only making 215whp at 9 psi now!!! omg i feel soooo maaaad. then again, i've had the car turboed for 1.5 years and have seen boost for 30K miles, and has been thru 2 summers. so i guess its from wear and tear.
but i was looking at the other guys readings and i'm like damn these other guys are making as much power as me now and they're only running half the boost. drats. i really looking to make around 250whp with my new setup. but i just dissapointed myself
there are a few more possiblities though
1) i'm running 5 zigen typhoons on this run vs. my old stock wheels
2) my rear brakes were slightly dragging
3) wear and tear
4) a civic with a B16a with cams, cam gears, 4 throttle bodies, headers, exhuast, and a hondata chip was being tuned by him and only made 165whp.
so this leads me to think the dyno is not reading that accurate that day. i have no clue. but i honestly didn't feel a lose in power at all from the day i got back from the dyno the first time over a year ago. hmmmmm
what do you guys think?
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
What was the A/F ratio?
And where is you timing set at?
And why 370s plus an FMU...?
- Brian
S14tat
Car: 2007 FX35
1994 Acura NSX
my a/f ratio is in the low 12's to high 11's. i know its very dangerous there but thats the only way i can break the 204whp barrier. the FMU is also being bypassed. i unscrewed it completely so like its not even there. my timing is also set at 16 degrees btdc. what are the chances of a dyno reading messed up? cuase i mean that civic was reading really really low too. that guy was pist. and i'm still pist!
also would not having a intake air temp sensor hooked up effect hp rating as well? and if so by how much?
:: orion ::
High-11, low-12 A/Fs look good.
Base timing @ 16 BTDC is OK for 9psi.
IAT makes NO difference in power.
Sounds like it might have ben a conservative dyno.
Have you compression tested the motor? Is it healthy?
- Brian
S14tat
Car: 2007 FX35
1994 Acura NSX
this is the same dyno i went to last year. however they're computer software seems alittle different. oh wells i'll do a comp test in school later.
