gawdzilla »
https://forums.nicoclub.com/gawdzilla-u19868.html
Fri Aug 07, 2009 6:45 am
no special tool needed. stock cams? i don't remember with the stock cams, but i think they might need to come out first. are you trying to avoid removing the cams? you will see relief indentations on the shaft that lets you get a socket by. i know the tomei's have this so you can remove the head without taking out the cams. might take some gentle movement of the cam gear to get it aligned properly, but check for the reliefs first. if there arent any the cams need to come out.
