Are you serious?
boogiesj30
Car: 93' Infiniti J30
My 93 J30 is dope, but I should have looked at it more before I got her. The brake lights do not work. I've changed the bulbs, and the are to factory standards. I right head light was out so I changed it. Now its out again, but when I changed it, it doesn't work. No high or low beam. My right turning signals are both out; front and rear. Is there a relay controlling the brake lights? If there is, where is it lease? Same for my head lamp. And can ANYONE PLEASE tell me where I can get replacement driver, and passenger seats. NONE ON EBAY.
Thanks a Bunch in Advance
Leuthesius
Car: 1996 Infiniti J30 - Totaled by Hail RIP
1995 Smurfima - Blown Head Gasket 230k miles RIP
Check all of your fuses. That will save you the troubles. They're under the hood. There might be an internal fuse panel somewhere, but I haven't had a reason to go looking for it yet so I dunno. Someone else probably knows. It sounds like you've got a bad relay.
boogiesj30
Ok, if I have a bad relay, where is it and where can I get one from?
naladude911
Car: 2001 Infiniti QX4
By your emergency brake pedal there is a remvable kick panel (on the right). Take that off a nd you will find a fuse box. Check the connections. Are all the relays securily connected? Have the bulbs been replaced? Try to find yourself answers for those, and if yo cant, then someone else has to help you....
boogiesj30
i checked the fuse box and changed the fuse. still doesn't work. Where is the relay? I have no idea where it connects much less where it is...
naladude911
il just wait for yoda or greatscott
brandonjustice93J30
Car: 1993 Infiniti J30
headlight relay is on the driver side near the firewall.You can grab a new one from Joe at everythinginfiniti.com for about $35.
you can DIY, depending on how comfortable you are with the car. But considering you havent located it nor the repair manual in the trunk that outlines the entire schematics and troubleshooting proceedures, then I'd suggest having someone do it for you. I had mine done just because I dont have the space to work on my car and two kids to occupy my time, and I got charged $90 for parts and labor.
taillight relay, I havent had any problems, so I dont know off hand. But like I said the handy-dandy service manual in the trunk will tell you where anything you want to know is located.
