Are you ready to cut your s13 dash for HUD?
94_240sx
Car: 94_240SX
This is 1:1 scale template. DO NOT use below image. Open up the PDF, print, cut and use it.
http://findjdm.com/hud.pdf
Here's the detail.
I spent a long time to come up with this template, so I can say it's VERY accurate. X-Acto knife will work great. You can use Dremel, but it'll make a mess under the dash. It doesn't have to be perfect since edge will be covered by HUD trim cover. Good luck!!
Disclaimer: It's not my fault if you mess up your dash.
leesredgt
Car: 1992 Toyota MR2 N/A
1991 Toyota MR2 Turbo
Very nice man.This should be stickied.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I assume your cutting the outer?
94_240sx
Car: 94_240SX
OutToWinPAHC wrote:I assume your cutting the outer?
What do you mean by "outer"? This is OEM mounting hole.
It looks like this when you cut it without the template, but it's still okay since the trim will cover it nicely.
mrgreeneyes
Car: ///M5
Parted Out Built S13 Coupe
i just so happen to have acquired a hud for this coupe. excellent timing sir
myfirst24010
Car: 1993 240sx, 2004 BMW M3,
or if livin in the nyc area buy my extra one
94_240sx
Car: 94_240SX
j240sxxx was the first person to cut his dash using my template and it worked out just fine. Like I said, trim will cover the area nicely.
s13kronzo
Car: 1992 Nissan 240sx SE
This is awesome. Could you please reupload the template? The link doesn't seem to work. Thanks
amolao
Car: 1989 Hatchback (the first one...) w/ Autech sr20de S15
use a sharp razor or exacto blade, do not cut sharp or go too far into the corners of the cut, or your dash will create cracks. Take your time with it...the photos in the thread show the way of how not to do it,....
