mv520 »
https://forums.nicoclub.com/mv520-u30862.html
Sun Aug 28, 2005 10:43 am
my motor has 135,XXX i plan on getting it rebuilt in feb/march/april. I bought a turbo kit for my 240sx. This is what i bought on ebay
"Up for auction is a used turbo kit off of my 89 240sx SOHC (ka24E). If your looking for a kit that spools hard and fast then this is what you are looking at. This kit has a T3 oil cooled ball bearing turbo, external wastegate with 6 and 8lb springs, Aluminum 2.5" piping all cut to fit any s13 style 240sx (89-94) with hand welded removable BOV (rediculously loud!!!!) And all the couplers that you would need. And the massive 31" by 12" polished aluminum intercooler!!!!! It also includes a 8:1 Fuel Managment Unit (FMU). Turbo has the function 7 inlet/outlets, and has minimal shaft play if any at all. Comes with the downpipe and wastegate tube that i was using, but they need some welding finished because we ran out of argon. It also includes the Sohc manifold that i made. It might need a new thicker falnge welded on, but thats about it.
This kit can also be used on a dohc 240sx with a different manifold.
XS T3 ball bearing turbo
Wastegate w/6 and 8lb springs
BOV and all the aluminum piping custom fit for the 89-94 240sx w massive intercooler
8:1 FMU, downpipe, wastegate tube, turbo fittings, and misc. hoses and tubes, etc."
So i will ill still lose to everything...
