Are vented hoods really worth it?
Sirk
Car: 97 Maxima SE 5SPD
Or are they just for looks? Would an OEM hood with washers on the back be more effective for controlling temps? Or would an OEM hood, no washers, with a Koyo copper and Altima fans be ideal?
naed240sx
Car: .....
you are gonna get a bunch of opinionated answers to your question. All of the things you mention will be effective at reducing underhood temps... but I dont think that anyone has actually done a test. Decide what is most practical for you, and then if you still dont like the amount of heat, add on something else.
chmercer
hood washers dosent do ****. ive had it on metal hood and fg hood, sucks. just gets leaves and crap in your engine bay.
yes vented hoods lower engine bay temps. its not just "for looks".
hek1620
Car: '89 240sx
yes but vented hoods also let a but load of rain in on ur engine. i'll keep my washers thank u much. even when i get an O.E. STYLE cf hood. plus vented hoods are just another way for people to mess with ur stuff. they could throw or spill whatever they want onto ur engine.
InsanityInc
SOME vented hoods work, most do not. Ask the manufacturer if the vents are functional before you buy one.
Modified by InsanityInc at 1:40 AM 9/7/2005
97ka-t
Car: 1996 Nissan Maxima
1998 Nissan Altima
It dissipates enough heat for me!!
chmercer
check your engine bay temps, it does like nothing.
yes i guess vented hoods would let water into your engine bay, i guess that would suck if you drive a show car.
pretty much every vented hood ive seen on the internet for s chassis is functional aside from the VIS hood with a vent on top of the radiator.
grimple1
Car: 95 240sx Zenki
Well since hot air rises, any venting will reduce temps. So a vent would work, a scoop would allow cooler air in the engine bay.
The washer thing seems a little non-efficient to me. You'd have to have a lot of washers under there to make it as effective as a vent/scoop.
You could just run hoodless. That'll vent the heat out.
HashiriyaS14
Car: '95 Nissan 240SX
'08 Honda Accord
'08 Honda NPS50
'03 Kawasaki Ninja 250
'60 Honda Super Cub
Depends. On an S-chassis....probably does a little something.
On something with a TMIC, like an Impreza, I'd expect it to have a bit more functionality.
InsanityInc
grimple1 wrote:Well since hot air rises, any venting will reduce temps. So a vent would work, a scoop would allow cooler air in the engine bay.
Blargh. No. Hot air doesn't rise when you're in motion. Air is flowing from the front to the back of your engine bay. Just punching a hole somewhere in your hood isn't going to let anything extra out while you're in motion. Sure, if you're really worred about underhood temperatures at idle it'll help, but I don't think anyone is.
A vented hood that really works has to be designed with knowledge of the underhood airflow, namely where the air gets turbulent enough to flow upwards and out a vent. On a 240, that's probably about 1/3 - 1/2 way back on the valve cover. The air is flowing pretty straight before it hits your engine.
Modified by InsanityInc at 4:50 PM 9/7/2005
BaliLover
I remember reading somewhere that the flow of air over a vent while the car is in motion creates a vacuum effect sucking the hot air out of the engine bay.
The old school cowl induction hoods for example, had no openings facing forward, but when the car was in motion air was sucked in due to pressure change. Or something like that. I'm sure someone out there can explain this effect better.
Lil_JV
Car: 1991 180SX
BaliLover wrote:I remember reading somewhere that the flow of air over a vent while the car is in motion creates a vacuum effect sucking the hot air out of the engine bay.
I believe this is true. No need for forward facing scoops. The cold air is sucked in.
grimple1
Car: 95 240sx Zenki
It's still rising, granted not in a 90 degree angle but it's always rising.
Modified by grimple1 at 7:33 AM 9/9/2005
97ka-t
1998 Nissan Altima
SloS13
Hot air rises whether in motion or not. A hole would create a vaccum (if at the correct angle) while moving. My car runs a couple degrees cooler with the washers.
rico05
Car: 1992 RMS13 w/ CA18DET
Just put some spacers under the hood hinges, and call it a day.
ArticDragon192
Car: 91 Z32 2+2
That's some? lol!!
wilfonzo
Car: s14
haha, thats badass
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
rico05 wrote:Just put some spacers under the hood hinges, and call it a day.
The man has a point people. Why waste money on some hood that invites water into your engine bay when u can just use spacers?
wilfonzo
Car: s14
im probably going to sound like an idiot, but what are hood washers
Kouki40
Car: 02 taffeta civic SI
just the latest in low budget JDM mods
