are they still making this sway bar?
ponzy
Car: infiniti q45
copied and pasted from q45.org tech help under suspension and handling tips:
20mm and 22mm swaybars for sale Author Post Sopdadope
Offline
Boston 7-26-2002 20mm and 22mm swaybars for sale 9:14 PM 10/28/2002
Hey guys. I know a few of you are interested in getting larger diameter rear swaybars for your first gen Q's. Well while I was getting my active suspension conversion done, I had a local shop custom fabricate a 22mm rear swaybar so if anyone's interested I have one active suspension swaybar for sale and I have a few 22mm bars available. I needed to place an order of at least 10 (otherwise they shop said it would've been a no-go). The cornering is great with a 22mm bar. The difference was noticeable even coming from a 20mm active bar. Between the 15mm bar the difference is night and day. Well anyway, I do have a few up for grabs and they're still cheaper than the $240 Infiniti of Scottsdale wants for each. If anyone's interested, email me at [email protected].
Q45techSuper Moderator
Offline
8237 posts1990 Q45 312,000 milesMarietta , Georgia 4-30-2002 9:14 PM 10/28/2002
The 22 mm rear bar should be 80-85 lb/inches [roughly double the active bar] at the wheel better than the 24 mm [122 lb/in] Stillen bar which is no longer available.Roughly a 50-60% increase in rear stiffness, you will need the rear Tokico Blues to help control it. Instead of a maximum 4" roll [no rear bar] you would be down to 2.44" at the max g vs a 20 mm's 3"
This might be the perfect bar if you have a standard Q and don't want to go thru the process of down sizing your front bar from 29 to 28 mm as used on the t and active cars.
The 20 mm is hard to get stiff enough [urethane] and the 24 mm bar is hard to get soft enough [rubber bushings] .
With a 29mm front and a 22mm rear [assumming 100% coupling efficiency] you would still have a 59-60% front roll couple bias so in dry you would still have a 5-7% understeer vs 30% stock at 0.7G................these numbers are rough but within 5% error so even with bad front bar bushings the worst would be neutral dry steering at the limit.
No bar can be coupled at 100% [unless welded in place] even with urethane as the end link angle changes even over +- 1.0"......so there is probably another 10% safety above my calculations.
Hey if people have destroyed themselves with a 24 mm solid rear bar and Stillen sold over 50 [we have 9 customers with them for years] sounds like a deal to me!
Sopdadope
Offline
Boston 7-26-2002 9:14 PM 10/28/2002
Just a heads up, I only have 4 bars left with 4 Energy Suspension endlinks complete with link and swaybar bushings. Over the past week I did a lot of car-car salesman duty at the car wash and convinced a few Q45 owners to upgrade to the 22mm bar (well a test drive in my car won themover). If anyone's still interested, it's $235 for the entire swaybar/endlinks/urethane bushings kit. Not a bad price at all, especially considering the difference in handling. :D
>>>>>>just a thought, if they're still in production? THANKS
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
Sopadope went to the WRX-STi side, so no.
ponzy
Car: infiniti q45
i'll be doing a lot of stuff on my 94 q by the end of this month: front suspenion to name a few. I cant find a cali spring so i would stick to the $140+ (EACH) spring back form JOE, but I wanna add additional handling benefits if i'll be installing new sway bar plus polyutherane bushings (fronts only)/ or just put a FSTB, but I guess there's no tower brace available righ now.
>>>>>> just gathering all available data/info as to WHAT and HOW MUCH those things are. thanks again.....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
Rear a model 20mm bar is plenty good, especially with a or t model smaller 28mm bar.
