duffman1278 wrote:wtf is up with that ECU???
Anyways, apparently you didn't search hard enough because these are common subject questions. First off, what motor is this? Redtop, Blacktop what? That ECU is for a redtop.
Ignitor looks correct
Does the MAF plug into the harness? But even than, I can't read the numbers on the MAFS
Its a redtop, sorry. I don't have the harness here to try the MAF. Do I need only the ignitor? Whats the other crap on the bracket?
I will search some more for the correct MAF Part number and compare.
Thank you.
