All the stock sets I have ever had that were never that yellow. the shafts were not raw metal color either.Kaforlife wrote:I've heard that some Ca comes with yellow ones but there a pale yellow just wanted to see if these where those
both should have there own stamp...Kaforlife wrote:Yeah I think I'm going to just take them out and look at the ends. Will they both be stamped or just one
I have RB injectors right now..... then are black shaft and off white clipsniscort wrote:tomei and Jun cams have some sort of stamping on the ends of shafts as shown on the hks cam above... they dont have logo casting marks as such..
as for injectors, look like rb26 gtr 444cc injectors
sounds like you have some laurel injectors... for a rb20, which are smaller than the stock cadet injectors. or if your lucky they are just stock ca injectors. rb26s are yellow as pictured and the only rb injectors larger than cadet injectorsca18detgabby wrote:
may look identical, but they definately arent.r34 gtr wrote:I apologize for the size of the picture, but these are my DSM 510cc/min injectors. They look identical to the ones the OP posted.
TMS pulled them for me from an RB and they def flow the proper 444 or I would be lean.......niscort wrote:
they are definately NOT hks cams... compare the surface finish of the casting to the ones meminto posted.
additionally, they dont need to be removed to see the end of the shaft.. surely you can see the ends of the shafts with the covers off.. take to halfmoon seal out
