Are these R32 GT-S LSD internals? Help before I install.
K-1
When I bought my car, I was also given the internals to a R32 GT-S R200 LSD. I have seen some pictures of different types of LSD's, but for some reason, this doesn't look like most I see in the pics.
Is it really a LSD? I am worried that I may have just been given some open diff parts maybe?
If it is a LSD, and I am going to install it, would it be a good idea to have a transmission shop do the work (I would remove diff and take to them). I don't think I could correctly measure and adjust the shims for the output shafts, etc.
Here are the pics:
silencer.1
Car: women, my car, paintball
It's not an LSD. That's just an open diff.
K-1
hmmm.
well then it's probably not from a R32 GT-S. Any clue what car it could be from, with the 5x1 output shaft bolt pattern?
240SicknessX
Car: 96 240 SE
silencer.1 wrote:It's not an LSD. That's just an open diff.
are you a thousand percent sure? in the first pic, the top center, thats what im questioning. maybe i have to take apart my extra open diff that i have and closely inspect the peices.could this be a hlsd? found in the s15?
the single bolt 5 flange output shafts are found in the 180sx, and the eariler infiniti j30s (all j30s are vlsd). (95-96 have 2bolt tri flange). i dont know about newer j30s then 96 which output shafts those are.
K-1
Quite a few people on other board believe that this is the VLSD from a R32 GT-S, so I wasn't mislead.
Here's a pic of an open diff, which this definatly isn't.
I need to make sure it's a VLSD so I use the correct fluid.
Wouldn't there be mechanical clutches in a normal LSD?
How can I tell that this VLSD is in good operating condition before I install? Or is it hit or miss?
Chingon
Car: 1991 and 1992 hatchbacks
that's a vlsd. That sealed disc is a dead giveaway.
