Are these quality problem issues????,
aricbeemer
OK, well I want to say that our Versa has a hatch rattle, dash rattle/creak, and the rubber seal off one of the doors started coming off. I know this is an economy car. But are these normal problems or should I be concerned? As a plastic piece for the rear seat belt on the rear seat cam loose as well. Forgive me for the Grammer skills BTW. And I should mention you can see the plastic piece on the dash closest to the windshield moves along with the dash. You can see the dash kinda bounce when on rough pavement.
Bubs daddy
Car: 2007 Nissan Versa SL
ABS, CVT
Every car has some kind of rattle or creak at sometime. One of the common complaints on any car forum no matter if economy car or luxury sedan.
Take it back to the dealer and get the hatch rattle fixed or just put the weather stripping back in.
aricbeemer
Bubs daddy wrote:Every car has some kind of rattle or creak at sometime. One of the common complaints on any car forum no matter if economy car or luxury sedan.
Well I hadn't really heard much about these problems before we got the car so I was just making sure.
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
The weather stripping around the rear doors has been discussed. It's been a problem for many people since it doesn't have a firm channel to fit in to and there's no adhesive on it. It comes loose very easily.
aricbeemer
srellim234 wrote:The weather stripping around the rear doors has been discussed. It's been a problem for many people since it doesn't have a firm channel to fit in to and there's no adhesive on it. It comes loose very easily.
So I know the dealership can fix it as they have fixed several items for free. But will they glue it on?
srellim234
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
It's up to the dealer. Mine just puts it back in place when it's loose at the dealer. When it happens at home I just put it back.
I'm going to put a few spots of silicone adhesive under it and see if that's a more permanent solution to the problem.
aricbeemer
The dealer is going to fix it for us.
