StrongBad240 »
https://forums.nicoclub.com/strongbad240-u6239.html
Thu Jul 03, 2003 11:02 am
This is what I got quoted at is this too much?
PARTs__
sr20det -2450 arp rod bolt kit -60ecu+wire harness service -400 greddy profec b -370greddy Intetcooler 24 type R -950 Apexi SAFC -300act clutch NS1HDR6 -363 cometic hd gasket 88.5mm -125silvia radatior (used) -60 auto meter angle trim -16Apexi Gt Cat-back -530 (hoses, belts and spark plugs, wires ) -75hks down pipe -300hks mass air flow adaptor - 35hks Intake _105oem water pump -125Turbo xs rfl bov -180arp head studs -16020" electric fan -902 5/8' egt auto meter gauge -802 5/8 boost " " " -702 5/8 oil pressure " " " -75
Labor___
R&R engine and transmission -792R&R rod bolts, head gasket, head studs -237resurface Flywheel -55R&R water pump _27R&R T stat -27Install & wire boost contoller _55Install gauges in dash pass side -110install SAFC -80install Clutch -60install intercooler -82install ecu and wireing -110install electric fan -55install exhaust system -55service rear diff & replace U joints _110
