mexillis wrote:Yeah everyone has a different opinion of what is poking out, sticking out, flush, etc. I was showing OP a link with the specs he's asking about and that nothing was needed for it to work; no pull or camber. If someone wants to sit like you are a 10.5 +48 is the exact same as a 10+42 using the offset calculator.
Well here is my opinion:
Tuck - wheel lip is 2-3mm or more before fender lip (tire or wheel will not hit fender lip at all)
Flush - wheel lip is even with fender lip (tire or wheel should not hit fender lip)
poke- wheel lip is 2-3mm passed fender lip (wheel lip may hit fender lip)
sticking out- wheel lip is 5mm or more passed fender lip (tire may hit fender lip)
IMO you should not be looking for wheels that stick out pass the fender unless you have some kind of plan to make the fender lip come out to the wheel lip, pull, camber, body work, air system or just a really low drop will be needed.
If your car is not dropped and your wheels are sticking out I'm sorry to say that it won't look good. Having a gap and wheels sticking out is not the way to go.
I'm not here to bash anyone, if I don't like it I move on to the next thread (which I do alot). If your in front of me bing in a meet, BBQ or even passing by my house I'll tell it to your face. I don't want to give false opinions, I don't like I'll let you know.
for those that don't want to go crazy and not have to do anything to the car your best bet is tuck or flush.
