Mister 26 »
https://forums.nicoclub.com/mister-26-u40125.html
Tue May 16, 2006 3:16 pm
I'm still quite the newb as I30 owners go, still in my first month. There are a few things that the car does that I wonder about. Maybe someone here can shed some light for me.
First issue: I've noticed that quite consistantly when I first start the car, for the first 15 seconds or so the car hesitates badly when I step on the gas peddle. Then after the 15 or so seconds, it runs fine.
Second issue: SES light has come on and gone off a few times. I've had the codes pulled and it says banks 1 & 2 are too lean. When I spoke to the service manager at the local Nissan dealership he claimed that he's getting lots of these codes recently because the gas companies are adding additives to the gas that lean it out. HE suggested I try a different gas station on the next tank, which I did and it didn't help. Is he bs-ing me? Do I have a real problem?
Third: The starter died this weekend, leaving me in the parking lot of the Petsmart. I've since had it replaced, which required pulling the battery. After I got the car from the shop it ran horribly, hesitating and stuttering. I took it back to the shop and the mechanic told me since the battery had been pulled the car needed to reset itself, or relearn it's settings like o2/fuel mixture, and that it should run normally within a day. On the way home I did notice it seems to run better. Was he bs-ing me?
Please help me stop worrying about this stuff, I've got plenty of other things to worry about just waiting in line.
Modified by Mister 26 at 6:29 PM 5/16/2006
