Are these headlight bulbs ok?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
sk16369
I was wondering if these bulbs were street legal and ok to replace the stock bulbs without replacing the harness or wires?
http://cgi.ebay.com/ebaymotors...A1318
Red Devil
Car: 1990 240SX w/t SR20
2008 Nissan Versa SL
You do realize those aren't HID's right?
feloniousmonk
I've posted on this several times. Please read it.
http://www.danielsternlighting....html
Shad0wXCalibur
Car: Nissan Versa SL Sedan
NO! The low beam is the correct wattage but the 100 watt high beam will melt your wiring harness and possibly the headlight itself leading to expensive damages that Nissan will not cover. Not to mention, the low beam will be whiter but it won't be brighter because the coating reduces lumens. Half of the info in their product description is false.
VersaMG08
Car: '10 Mazda 3 s hatchback
'14 Nissan 370z
That information posted on the ebay product is false information. It's only coated a different color to imitate a blue color temp.
Red Devil
Shad0wXCalibur wrote:NO! The low beam is the correct wattage but the 100 watt high beam will melt your wiring harness and possibly the headlight itself leading to expensive damages that Nissan will not cover. Not to mention, the low beam will be whiter but it won't be brighter because the coating reduces lumens. Half of the info in their product description is false.
Because it is ebay, and most of ebay sucks.
Return to “Versa Technical Discussions”
