are these going to stick out to much?
karmakaze
Car: 98 240sx SE
I am thinking about buying a set of rims from this guy, i am trying to decide if its a good idea or bad idea.
here is the car with FNs on it. (i would just measure clearance, but i only have stock wheels, the picture below is from before i bought it) it has 30mm fenders up front and 50mm fenders in back. The sizes on it are 17x9+15 and 17x10+12. The ones I want to buy are 18s and will extend the front by 31mm (1.22in) and the rear by 40mm (1.57in).
The widebody panels were on the car when I bought it so there isn't much that I can do with them.
Is that going to stick out a bit to much?
ArticDragon192
Car: 91 Z32 2+2
So wait, why not post the sizing of the wheels you're gonna buy? Because your post is a little confusing. Or are the FNs you posted the ones you are getting?
karmakaze
Car: 98 240sx SE
i am getting 18x12+3 and 18x10+3
nismofly
Car: 89 Nissan 240SX Hatch
itll fit nice up front, the rears should work too, because youll be able to work the fender a bit to make them perfect
