Are there anymore grounds???????????????
tight240
Before anybody start flaming me, or directing me to the search button, i've done all of that, i have been on here, racebread, and 240sxforums.com. Now my question is, are there anymore grounds besides the one that goes to the ignitor chip, and the 2 thats in front of the intake plenum on the RB20's? I have everything hooked up right, but my ecu light is dem, and i'm thinking that there should be more grounds instead of the ones i just named . Any help would be appreciated.
gbaz77
Car: 240sx
your ignition relay has a ground that you need to connect. its from the dash wire set, you need to ground that if you havent already ( i belive its the black wire, but i would recommend you check a wire writeup there are a few on http://www.racebread.com, skillzillas is good).
tight240
Believe me i've checked, i have read both skillzilla's and carl h's write up over 100 times no b.s. I see your local, do you have yours up and running?
gbaz77
Car: 240sx
yeah it is.
heres my email [email protected]
shoot me an email and maybe i can come by and help with what i can.
gamay
tight240
I'll definately hit you up, my car is here at the Nissan dealership on Security Blvd. let me know what your schedule is and we can hook something up.
Im still open for advice.
gbaz77
Car: 240sx
ill be at OC this weekend, but email some possible time slots for next week after 5pm and we'll get together.
tight240
I found the problem, i will be contacting you anyway to check your ride out and everything, i havent seen a RB20 in a S13 yet.
