are there any problems to look forward to with an 03z
Nissan 350z / Nissan 370z general community discussion forum
LIbadboy
Car: 350z soon to come
im ready to get my first z but have read that it has some problems with the transmission and the rear axel. also something about the tires feathering.....i really want this car but im going from a car that had transmission problems from day one so i want a problem free ride thanks.
C-Kwik
well I guess this posts answers my question from the other thread you started. The 03's did apparently have a high occurrence of the problems you mention. From what I can tell, the transmission problems were hit or miss, but it was more of a problem than in later years. Tire feathering may be a problem, but personally, I think it's more of an issue you;ll fond common to some extent in many high performance cars. As anyone tried to enhance performance by optimizing alignment, you tend to get wear issues with the tires. AS far as the axle problem, if you are referring to the clicking that people get, the axle nuts on the hub just need to be retorqued. Happened on my G35 and took it in for warranty. Hasn't had a problem since.
LIbadboy
so in other words nothing really to major that should prevent me from buying this car...if there is a transmission problem how many miles does it start in at and what are the symptoms...also is it an expensive fix...
fukjdm
Car: TK350z
from what i heard, 03's respond better to mods without throwing codes.
jEzTeR
Car: '07 Infiniti FX35
'02 Nissan Altima SE 3.5
'93 Nissan 240SX Hatch
03/04 350z's are getting cheeper and cheeper. You should have no trouble finding a good deal on one.
Most are priced between $22K~$32k.
BlasterZ
Car: 2003 350Z / JWT Pop Charger and 1997 Eclipse GS-t Spyder
I have that same clicking in my 03 Z. I will retourqe the lugs! So simple looked over thanks!
Exar-Kun
Car: 2005 350Z
I was wondering what the hell that odd clicking sound was when i went to back up...
-Chet
Return to “350z / 370z Discussion”
