mexillis wrote: ↑Tue Apr 23, 2013 3:38 pm
As for smoking a new 5.0 did he know you were racing? I can see maybe you winning from 0-40 from them trying to get traction but no way in a 1/4 mile. Im sure the gears make the car faster but not gain a hundred whp lol.
I know its an old thread, but I figured I should point out that by going to 4.083 ratio from stock, he gains 21% torque at every RPM. That is a significant increase and is especially handy in the low rpm range for the "get up and go'ness"
@clintguy
You ever thought about moving to the highest ratio Nissan sells, the 4.36? That would put you at a 29% torque increase over stock. If you arent doing major power mods (turbo, super) then it would be a great mod to do. If you are going FI of course the whp will be so high that a ratio like that would probably just make you spin tires all day long. lol
And I have to ask,cause I was the second person who has ever done this swap on an M after Ken's post, how did you get the gears to fit your diff? Did you go with a manual diff to begin with and swap the driveshaft connection? Or did you have an automatic differential and when you put these gears in swap out the whole back plate on the diff? I had (have?) a set of 4.083s I bought a LONG time ago cause I wanted to do the swap, but they wouldnt fit right and never got around to making it work.
