+1, exactly what I had to do.Darius wrote:The plugged port towards the rear of the block is the coolant drain fitting for the block. I wouldn't try to get oil from there
You'll probably have to run 90 adapter fittings right off the block to keep the fittings shallow with respect to the manifold.
