are the valves on a 95 hydraulic?
nquestion
are the valves on a 95 hydraulic? if not can they be adjusted? i hear a little noise comming from under the valve cover at idle, i've already removed the timming chain guide, so i think if the valves are adjustable that would be a place to start.
i'm having a hard time finding a chiltons manual. i guess i will have to go by a fsm. $$$
niznos
Car: 03 Z-track, 98 Maxima GXE, 90 240SX RIP
I am pretty sure the DOHC's are NOT hydro., they must be adjusted to spec. by hand. We SOHC's luck out here.
leper421
Car: Current: 2011 370z
Previous: 2003 350z, 1991 240sx
The DE does not have hydraulic lifters. To adjust the valve clearance you have to replace shims. They go for about $10 a piece.
