Are The Stillen Cams Any Good? How Much Hp Gains Are We Talking About At The Wheels
NISMO24096
JUST LOOKING TO MAKE SOME WISE BUYS AND NOT GET STUCK WITH SOME POS, ALSO ANYONE IN HERE GOT A OPION ON THE UNORTHADOX SS UNDERDRIVE PULLY SET, IS IT WORTH THE 400+ PRICE TAG.
R240NA
Stillen doesn't make KA cams. Hard to tell you what an imaginary item will do. More research and taking the capslock off would be nice.
NISMO24096
well sorry about the caps lock but unless im reading my oct 2002 sportcompact and the stillen website is wrong then they do indeed have cams out cause they are wanting 702 dollors for them. hey even i think that is alot of money for nothing so im thinking there is something there its for the 91-98 240sx and has a part number of 400020. but hey if im wrong oh well but im just going off what i read....
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
Looking at their website, it lists it as a U/G. To me this means Un-Ground. You may want to call them to get the specs. With the specs i could tell you how good they are.
NISMO24096
tru, i will call them later on and get the specs for the cams, i see that you run the centerforce stage II, how do you feel about the ACT clutches, i was wandering if the 6 puck really was too rough for use on a street driven car..
JNM240
hehe i just posted my reply to that. peace.
Lobot
NISMO24096 wrote:JUST LOOKING TO MAKE SOME WISE BUYS AND NOT GET STUCK WITH SOME POS, ALSO ANYONE IN HERE GOT A OPION ON THE UNORTHADOX SS UNDERDRIVE PULLY SET, IS IT WORTH THE 400+ PRICE TAG.
According to the latest Import Tuner the Unorthadox Racing Pulley set makes 9hp at the wheels of a '96 240SX. its really up to you if you want to spend that amount for the hp, I'd say if your sticking with the KA and planning on doing a lot of performance work it might be worth the price.
Turbo_Nismo_EC
Car: My truck...of course
I knew a guy that swears up and down that those pullies are horrible for the engine. He installed the unorthadox pully set and blew his motor 2 weeks later. He bought a new(used from a salvage yard but with 50,000 miles) and blew it up in less than 2 months. He went back to the old pullies and with a new salvage motor it has lasted, to the best of my knowledge, for about a year so far. He said it's something like the damper is gone and it vibrates too bad at high rpm and makes his spin a bearing. But then again, that is just what he said, I never seen the motor or anything.
R240NA
Lost_To_A_K-Car wrote:The OEM crank pulleys have a harmonic balancer on them. The Unorthodox pulleys do not. With the long stroke of the KA engine, the balancer is needed to prevent hosing your crankshaft.
In short, the underdrive pulleys are a Bad Idea.
I've heard both sides of the fence. I've got a UR pulley with a Stillen flywheel, 3 years with no problems. I beat on it hard everyday.
NISMO24096
i know that early on the UR pullyes had problems with wearing throught and leaking but that has since been taken care of actually i think they redesigned the pully itself awhile back, so if your friend had that kind of problem it was most likely with the first production run of the pullyes..
