PMan_S13 »
https://forums.nicoclub.com/pman-s13-u3715.html
Sat Nov 15, 2003 1:02 pm
Ok, so my KAT has been smoking and burning a pretty decent amount of oil. At first I thought I might have popped a piston ring, cracked a ring land, or blew a valve seal.. or something. It's not a very consistant smoking, comes and goes for the most part. But it is much more likely to happen if I let off throttle but goes away after it all blows out. When it happens, it's pretty thick, like embarassing thick.
So I tested the compression.. everything is still good. So I'm assuming it's not from the afore mentioned rings, lands, or seals.
There was no oil on the spark plugs.. (actually they were slighty oxidized, so I turned up the fuel a bit on the AFC =P )...
Now doesn't that mean it's burning oil somewhere after the combustion chamber? Like, uh, the turbo?
There is also a "healthy" amount of oil in the hot pipe, but just a light film of oil (from the pcv blowby) on the intake side.
I haven't taken off my downpipe yet. I need a new downpipe gasket (btw, anyone having trouble with those gaskets blowing out? I need to find where I can get a metal downpipe gasket) and not wanting to have a tremendous exhaust leak. Sooo I'm not sure what it looks like in there.
Right now I'm pointing to the turbo, but I really don't know for sure. With the oil in the pipes, the clean spark plugs, and the fact that it didn't burn oil at all before being force fed, I'm guessing that my brand new frickin turbo has bad seals.
Anyone else want to take a guess? :help
