dal2kvvisp »
https://forums.nicoclub.com/dal2kvvisp-u16332.html
Sat May 14, 2005 9:53 am
wow, you are definately wrong, the sohc transmission WILL NOT fit on the DOHC transmission, we just tried it last night thinking it was the same as well. we took a 5spd out of a 92 because it was really messed up, grinded like 2 gears, didnt go in sometimes etc, and we had a sohc laying around, so we put em up to each other, and they looked the same, so we tried putting it in.
4 hours later, trying everything we knew, still no transmission in the car, so we take it out from under the car, and check it to see if it really IS the same... because it came out easily enough. the sohc transmission looks the same, but ones more oval than the other, sohc and dohc are not interchangable
