Bronze MFP »
https://forums.nicoclub.com/bronze-mfp-u7726.html
Wed Jan 10, 2007 11:48 am
i'm also on carolinanissans.com and it's a pretty slow site. anyways, here is the skinny on engine swaps in NC. basicly if your car is 1995 or earlier, you do not have to pass any sort of emissions test. They only do safety checks. They will check for emission equipment so it only has to look like you have all the equipment on your car (or at least most of it...). So you can have an engine swap and get away with it. Seeing as how 240's came with a resonator that looks like a cat, as long as you keep that, make your carbon canister look like its hooked up (or hook it up, doesn't matter) you should be good to go. Having a friend that does inspections doesn't hurt either.
