Jesda wrote:I've tried my best to understand LSD. I've googled the heck out of it and made sure to check howstuffworks.com, and despite all the fantastic mechanical explanations none of them basically say what it does.
When a wheel starts slipping does it simply apply power to the other?
-Jesda
depends, there are 3 main types of lsd. clutch type, helical, and viscous.
in a clutch type, there are clutch plates that are preloaded with a spring on both sides of the spider of the diff that force the wheels to turn at the same speed, unless making a turn.
helical has a complex setup of gears within the diff case that can transfer a predetermined amount of power to the wheel with traction. [helical lsd will not work with one wheel in the air, both wheels must have some degree of friction]
viscous units have a device thats filled with silicone viscous fliud that heats up when one wheel spins faster, becomes stiff and locks both axles together
