are s13/t25 and s14/t28 sr20 turbo lines interchangeable?
Kalypso
I bought s14 turbo oil/coolant lines by accident, are they the same fittings?
Kalypso
anyone?
yes or no
Emperor_Tha
iirc one of the s14 hard coolant line connects to the upper coolant neck where as the s13 connect to the block.
Hijacker
Car: '92 240sx Convertible
'94 F-150
You are correct.
The coolant line from the heater hose and oil feed line should be similar. You can still slightly bend the steel lines to work for your application. You just have to be careful of kinks and having the banjo fittings turned funky.
But the S14 block coolant line is definitely completely different.
Kalypso
I am confused. out of these lines, which ones can be used. assuming the thread pitch and diameters dont change (unless they do) here is what I got...
my situation doesnt sound hopeless. ill just use what I can, but i shouldnt have been so impulsive.
Hijacker
'94 F-150
You could have said they were SS lines. When you say you have S14/T28 lines, I'm assuming you have the hard lines.
Kalypso
my mistake completely.
so... am i straight?
Kalypso
can anyone confirm this,
jeking1
Car: 95 240SX SE, sr20det, time attack advan avs, megan coilovers, mmm mmmm good
yeah, you should be good, only thing I forsee is having to slightly move the lines due to clearance issues with intake and heater hose in the rear. as long as those done leak you will be good to go.
