RobertsnewQ »
https://forums.nicoclub.com/robertsnewq-u29366.html
Fri Sep 02, 2005 7:27 am
Yep, it's been beaten to death and rs covered it pretty well. From what I've read (correct me if I'm wrong) the G50 diff carrier won't put the 4.08 ring in the right position to mesh with the pinion. The regular r200 diff carrier won't work with the G50 stub shafts and possibly diff bearings.
As for swapping hogsheads, I've verified at the junkyard that the Z32/Y32/Y33/R33 pumpkins are all the same dimensionally and all have the 5-bolt output flanges.
The 300zx stub shafts might work with a spacer but I'm 90% sure it would have to be thicker than 1/4" - more like 3/4" from my rough measurements.
Y32/Y33 shafts (they are the same) won't work because they are too short and have the same CVs as 300zx on the inner end. I suspect they are the same as 300zx shafts.
The new G35 rear will probably work but it has even worse ratios.
The new G35 axles have the same splines as the G50, which are larger than the splines on the Z32/Y32/Y33 etc.
The only one I've never checked is the 300zx turbo, but it is a r230 and doesn't have the good ratio.
What we need is someone to make some custom axles. Should be cheaper ($300 or so) than the spacer/custom rear setup.
