Sopdadope »
https://forums.nicoclub.com/sopdadope-u303.html
Fri Apr 23, 2004 6:57 am
It's been two years since I did this and I replaced the OEM bushings with ES urethane bushings. While the passenger-side was fairly straight-forward the driver-side had me tearing my hair out by the handful.
Because it's an odd tear-drop shape, the d/s bushing didn't seat properly against the rack. After much loosening of the steering column, endless prying, liberal amounts of lube and the use of two channel locks, I finally got it to seat properly. Careful not to let the steering shaft separate while loosening, otherwise budget at least an hour on reconfiguring the shaft to its proper, original setting. This is a deceptively difficult task and would be much easier to do on a lift. But if you're gungho about DIY, enjoy a challenge and have a good three-four hours to kill, go for it.
