Are QR25DE heads resurfaceable?
V6er
Car: 2014 Nissan Rogue T32 SL
2023 Nissan Rogue T33 SL
Yello, again!
MY2014 Rogue, QR25DE, 207kmiles.
thinking/researching about taking head off and showing tender love and care to it stumbled upon this little writeup in FSM(Engine mechanical - cylinder head disassembly):
sooo... according to FSM seems like - if there is any distortion - replace the head? do not resurface? or am I reading it wrong?
VStar650CL
Technical Expert
2004 Nissan Altima 2.5 S
They aren't supposed to be, but if the distortion is only a couple thousandths then you can probably get away with milling it. If it's at or near the 0.004" limit then you're probably playing with fire. Cast aluminum isn't very plastic, that much distortion usually means there are internal flaws or fractures.
V6er
what about different thickness head gaskets? tried googling - could find only original and cometic one thicknesses...
VStar650CL
Technical Expert
I don't know of anything for the QR engines. Like I said in one of your other threads, nobody I know about tries to f#ck with those heads in-shop. Late model Nissan heads don't even have bearings, they're all treated surfaces that you toss the head if they wear out. The bottom line is, they're meant to be disposable and you're trying to do stuff nobody ever does.
V6er
...I guess I need to discuss my future living arrangements with doctor :D
anyway - thanks for reply! :)
VStar650CL
Technical Expert
V6er wrote:
Thu Oct 16, 2025 10:20 am
:lolling: :lolling: :lolling:
V6er
@VStar650CL, you won't believe what happened yesterday.
was coming back from store... and suddenly realized that there is no check engine on instrument panel....
got out of the car - running smooth.
either car is self healing or I am "car whisperer" (alternator healed itself too :D
VStar650CL
Technical Expert
Carbon?
V6er
I guess so. that is only thing that comes to my diy mind. probably will check spark plugs and compression soon :D
Return to “Rogue Forum”
