ok.. DO NOT LAUGH.
every car I've owned, I've only had to swap the front brakes. Rears never wore out.. until now.
So after much cursing and swearing i get the caliper and wheel off. Get the pads out. And stupid me, i decide to try to compress the caliper piston with a c-clamp, thinking they were like the fronts. I wasn't after 2 clamps and a bunch of reading later that i discovered they needed to be _screwed_ in.
In any case, without thinking, I took the caliper assembly out of the car, put a used brake pad over the piston, a sparkplug socket on top of the brake pad, and proceeded to whack the mofo in with a hammer.
Yes. DO NOT LAUGH.
It _seems_ to work ok. Yanking the ebrake leaves two strips of rubber.
Anyone think I did some serious damage to the caliper? Recommendations? Should I replace the caliper? I'm saving up for the Z32 upgrade, but that won't happen for another year or so.
Thanks in advance!
