DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Sun Nov 21, 2004 11:33 am
Sounds right to me. Most MAFs run at 5.00 volts reference. They are designed for your car's engine, such that when you hit redline, the "sensed" voltage going back to the ECU is around 4.5 V. It can't be higher than the reference voltage, but for best resolution, it should be close to 5. The amount of air drawn in at redline varies from engine to engine, depending on displacement and RPMs, plus forced induction MAFs must have an even wider range than NA MAFs.You can swap the MAF, but I agree you'll need to mod/swap the ECU and get larger injectors for it to run well. A fully programmable ECU is the way to go if you want to change one thing at a time, but it is a lot of work. You'll be plugging in hundreds of numbers into the timing and injector tables. But if you get it right, it'll run great.
