Drake57 »
https://forums.nicoclub.com/drake57-u87237.html
Fri Apr 11, 2008 9:25 am
when they are in service for some time, or are most if not all lower O ring problems due to improper or careless installation, or defective/wrong parts?
VH45 fuel rail design seems unique in it's penchant of lower O ring problems leading to hydro lock - apparent undesirable feature of side feed injectors. I've read with interest the hydro lock threads - I'm beginning to dread turning the key.
If a 90-94 Q idles and runs smoothly, is that assurance enough of proper lower O performance? Is a fuel pressure bleed down check appropriate or indicative?
Lastly, are there any simple steps to be sure of proper lower O installation, other than using Infi parts, and being careful? I've seen mention of sending in the fuel rail for rebuild, but does that help insure proper lower O installation?
Thanks, Drake
