are intake mods worthwhile w/ stock exhaust?
diggler
Car: 2003 G35 Coupe
i'm interested in the following mods (03 coupe)
- JWT pop charger- Z tube- Skunk2 Plenum spacer (5/16")
everything on the car is stock so far. i don't have enough cash for an exhaust sys, so is it worth doing these mods for performance reasons only if i keep the stock exhaust?
thanks
Fenvy
Car: 2005 350Z Base 6MT
is you plan to get exhaust eventually... why not?
most of us don't have the cash or even if we do, we probably don't do evenrtyhing at once unless cost of install becomes a factor
I vote go for it and get exhaust later
joe603
Car: 2014 Durango R/T
You'll be very happy with the sound the JWT charger/Z-tube gives, and it does free up some horsepower (8-10 with the spacer). An exhaust system using the stock CATs will not give you as much "bang-for-buck". Plus, the stock exhaust sounds great stock!
In the words of Gov. Aanuld....DU IT NOWW!!
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
Why not go for the Motordyne spacer instead of the skunk2. Most people complained about it.
diggler
Car: 2003 G35 Coupe
i feel like if i do the jwt pop charger with z tube, it would be useless or almost useless to do the plenum spacer too, unless i get a new exhaust. basically, if i want to increase hp, i have to shell out a lot of cash at the beginning (exhaust), then i'll see the improvements that i'm looking for with the cheaper stuff. it's taking the big first step that holds me back. maybe there's a good deal out there for exhaust that i haven't found yet. any hints?? cheapest i've found is $725 for borla.
so, Motordyne's Iso Thermal plenum spacer is the way to go (instead of Skunk2)??? is the iso thermal any better than the basic spacer? the price difference doesn't matter, just curious.
joe603
Nissan did a very good job on the exhaust, which is why gains are limited when replacing from the converters-back. Unless you do a complete exhaust system (headers/strait pipes/aftermarket CAT back) you will not gain that much HP.
Doing the cheaper intake stuff first yields about the same as only doing just a CAT back, for a lot less cash. Now if you do everything at once, CAT a back and intake mods, that’s a different story as they work well together.
I've heard good things about using the spacer in combination with the Z-tube/charger, even without touching the exhaust. So, with all intake mods completed, you should see around 15HP, which is the same as a CAT back...
diggler
Car: 2003 G35 Coupe
i found a post with sound clips of aftermarket exhausts for the 350z, but i haven't seen/heard any for the g35. does anyone have these clips or a link to them? thanks
I have the Z tube and Motordyne spacer and love it.
Skip the Skunk, you don't want the free vacuum leak they include in their package.
C-Kwik
Hey...at least it's free...
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
Z tube, pop charger and 5/16 MD spacer is the only way to go.
