Jesda wrote:The Japanese concept of luxury seems to emphasize passivity. You sit; the car drives. This is why fatty lumps like the Lexus LS exist.
This is why the F50 can't carve a corner like an E39. It wasn't made to.
Lean the seat back, light up a cigar, turn on Al Green, and cruise. You'll reach your destination more relaxed and more satisfied than anyone else.
Basically, my suggestion is to get a BMW.
Not so, Jesda.
The G50 when introduced, and for quite a few years after, was a good example of how the Japanese CAN build a high performance luxury car. The same goes for the second gen M45. But all cars can benefit from some tweaking. I'm not trying to make a race car of my F50, but rather a competent and accomplished GT car. I believe that the F50 already has most of the basics. As it stands, it's far abiove such examples as the LS460, and the front drive Acuras, and such cars as the more mundane Saab, Volvo, and a few others that aren't even in the same class as the Q45 but cost as much.
The F50 already has an excellent engine that can benefit from a few minor bolt-on changes like ECU, intake, and exhaust systems. The intake and exhaust sytems can be done for a reasonable amount of money, the ECU admittedly more bucks, but the improvements would make it a formidable foe in ordinary road circumstances, even against the non "M" versions of the BMW like the 545 ande 745. A mere 20 cto 30 hp gain would put it right where I feel it should be. Likewise the chassis. It's really not "bad". It merely needs a few minor mods like sway bar changes, perhaps springs, and replacement of steering and sway bar bushings with slightly firmer ones.
The F50 corners flat, and has an excellent turning circle, indicating a well-thought out steering ratio. It only lacks a little in further development of more positive feedback to the driver, and that's not impossible. It would just take a little careful study, and attention to detail.
Before I bought my last 3 Q45s, I had 10 new high performance Corvettes, all special ordered with the biggest available engines, strongest 4 speed trans, special suspensions and wheels/tire, etc. Yet they weren't good enough for me. I developed them into examples that were still comfortable vehicles that were easy to drive on the street, yet able to dust off anything I came up against. I even had one of the only factory L-88 Corvettes delivered to a retail customer in 1969, of which the story of my getting it is an interesting and fun one. Yes, I even had to tweak it. It even had Michelin "XWX" tires, $400 each, a lot of money in 1969. When I was finished with it, it was an absolute pavement wrinkler, one that would run and corner with the very best of them, yet was a joy on the many 300 to 400 mile road trips I regularly took throughout the Midwest, running at 135 to 160 regularly for long distances, fun all the way, but a pleasure to drive, especially at the speeds I ran.To allow these speeds at night, it had jet aircraft landing light with custome wiring, 2@ 200,000 cp each,and 2@ 290,000 cp each, plus export low beams. I could see at night well enough to drive at over 150 mph. With a 3.55 rear end, and a 7400 RPM redline, it was capable of 200 mph, although I only took it up to 180 by the tach, and that only once. Beyond that speed, it got too light.
I'm never satisfied with stock vehicles. While in my older age, I enjoy comfort and luxury more than I did when I was young, I still demand above average performance. I believe that the F50 CAN deliver what I like and want. It's just a matter of a little development and attention. As with any other challenge, it's a matter of will.
I ask then for any suggestions anyone here can offer, and will of course share my own discoveries with others too.
I've already started with my new TSW "Kyalami" 18x8-40 wheels and 245/45ZR18-100W "Pole Position" tires. They have helped, but are too heavy. I plan on replacing them later on with good lightweight forged OZ or BBS wheels and PS2 tires in the same size. I also plan on dropping the car very slight 1/2 to 3/4 inches. Even such minimial reductions in height improve the cd more than one might expect, and the lowering of the cg aids in handling a considerable amount. The semi-active shocks are excellent, and don't need any changes. I also plan on working on the intake with a naturally but forced cold air intake sytem.Later will be a lightweight stainless steel larger more straight through but adequatel muffled exhaust system. Somewhere along the line, I hope to find a tunable or at least upgraded ECU that will provide a little more spark advance and moderately firmer shifts, no speed limiter, and hopefully, a higher cruise control maximum speed.
When I'm done, will it beat a new BMW M5? Not hardly. But it WILL smoke any other non forced induction and/or non NoS Q45, as well as most comparable Mercedes and 545s.
That's what I'm looking for.
Stay tuned.
In the meantime, I ask for any tips others may have learned on the F50.It's too good of a car to let it languish as an old geezer's fast sofa.
Come on, guys. Which of you will refuse to accept "it can't be done"?
