http://www.tirerack.com/tires/...g.jsp
In soft compounds probably as up to certain speeds - the normal hydroplane threshold is much more a function of tread softnesss than tread design.............at the ragged edge on wheels that steer directionals probably help a little when new.
How did the industry get in this mess? At what point in wear does the harder compound out weigh any benefit derived from directionality........ When the tread is half worn.
From tirerack site: "NOTE: Since we test new tires, the Potenza S-03 Pole Position’s feature that our testing didn’t evaluate was the tire’s ability to retain a greater percentage of its wet traction as its tread wears down.".............they are warning you that their test are only valid with BRAND NEW TIRES not tires with any wear!
