are coupe endlinks smaller than the sedan endlinks
4drmadness
Car: 04 g35 infiniti sedan
hey guys i have been having a clunking issue in the rear due to lowering. I have a revised 05 z suspension. I was looking into getting new endlinks, which might solve the problem. I cannot afford the adjustable endlinks because they are super expensive. I just wanted shorter and stronger endlinks. Are the coupe ones any smaller?
tollboothwilley
Car: 2003 G35 Sedan w/ NAV
The endlinks are all the same..coupe/sedan
The only thing that changes is with aftermarket sway bars you get different angles. This is the cause of the endlink clunk. Have you talked to riverside infiniti yet? I'm curious to know about the revised endlinks
4drmadness
I havent really talked to them, but i think an aftermarket endlink is the only way to go. It has to be adjustable so the endlink is not in any angle. The revised ones will have the same problem because it will act the same way as the stock endlink. I just wish SPL and Powergrid wouldnt be so expensive. If i go with one of these, i am only getting the rear ones. this way i wont have clunking and its easier to buy. this guy on the other website is selling F&R for $250. they are the spl ones. Let me know if you want these.
RED_DET
Vendor
2011 Infiniti G37x
Chevrolet Corvette Z06
I was having a clunking noise in the front on mine. When I was putting the new wheels on, I checked the endlinks and the damn bolt was loose. Tightened it up, no more clunking. There is a difference between the years though, the 05-06 endlinks are suppose to be "beefier".
tollboothwilley
the common issue is with the REARs clunking when you have aftermarket sways...people have blamed this on weak rear end links.
I'd like to think its something else but the only people i know who have eliminated the clunk used aftermarket endlinks.
4drmadness
just bought some spl endlinks. i will let you know if that resolves the issue
tollboothwilley
did you just get the rears?
4drmadness
yup just the rear ones
zozoka1212
Car: 08 Infiniti G35x
So the coupe guys have the same size. I always thought they buying coupes because they have a smaller one.
j/k
zozo
tollboothwilley
like they are compensating for certain things??
4drmadness
dude get the adjustable endlinks. clunking is gone even with one spl endlink installed. the side that has the endlink feels more sturdy as well. worth the money IMO
tollboothwilley
Wow. sweet. Worth the cost then?
What did you pay, $150?
4drmadness
paid 95 for used ones
