TD or Not TD »
https://forums.nicoclub.com/td-or-not-td-u67614.html
Sun Oct 28, 2007 8:42 pm
well i ran the car without the crank pulley in, had that large washer underneath the cover so i figured i was safe..... it was all together except that and the accesorie belts... well that disc flew out and somehow the gear slid right out and the timing belt came off completely. but im sure the valves are now bent.... i cant line up the timing marks. i put the crank on the right mark then i cannot move the cams past a certain point the 1st and 4th cylinder intake and exhaust valves wont open all the way. i dont know why but maybe its only one cylinder but thats the lobe that is almost all the way open looking at the cam lobes.
this makes me want to give up on the car, but its my own fault. the local guy usually gives me a good deal on my motors. no harness ecu or any intercooler stuff but i got my last one for $650.00 so i might be able to get them down a bit because this motor i got seemed like it smoked and some stuff was broke so we'll see.
