NolimitZ32 »
https://forums.nicoclub.com/nolimitz32-u100070.html
Wed Jan 29, 2014 3:33 pm
^ Don't really understand whether you are trying to refute what I said or not but if you are I can guarantee you that you have already lost the argument. What I said has been done on many a MAF car. Doing a blow-through setup is only hindered on the Z32 by the limitations of tuning the factory ECU. A MAF sensor in essence is a better system than the MAP because it measures the actual amount of air coming in where as the MAP sensor uses pressure to pull values from a table. As for what I said, it stands true, its a mechanical/physical FACT, and it is possible to make it work on any MAF system the only difference is the amount of money you have to throw at it. Finally, it is impossible to properly tune for the opening moment and loss of metered air in a pull-through system, you can get close but you'll never get it exact.
