are asjustable tension rods ok for daily driver
Acuratechva
Car: Black Kouki
none of those rods on ebay have rubber bushings like factory. are they designed for track use only? will they change ride quality at all on a daily driver
PGBrian
i have some for every day sriving.no dust boots either.they are Battle Version arms.they will make the ride more harsh. you are eliminating a rubber bushing and putting metal/metal instead. so you feel a lot more imperfections in the road
MarkEmark
Car: fully-built '95 240sx KA-T
I think the increase in ride harshness is negligible, especially if you're running aftermarket (stiffer) suspension. What I did notice is a lot more steering precision and a better overall feel...you'll be fine.
Acuratechva
Car: Black Kouki
how do i know if they are set to factory length? are there marks on them?or will i need to align the car? which will not be a problme ...i can do that at work on my lunch brake.
chmercer
how do you know if they are set to factory length? hold them up to the stock tension rods and if they are the same length, there you go. dont worry so much.
Exar-Kun
Car: 2005 350Z
Hush. Yes, check the alignment, your caster will be off when you install them. Adjust them as needed to get your caster to spec. Don't eyeball it and think it's going to be fine...
-Chet
book-ends
Car: ???? Nissan 240SX coupe S13
Exar-Kun wrote:Hush. Yes, check the alignment, your caster will be off when you install them. Adjust them as needed to get your caster to spec. Don't eyeball it and think it's going to be fine...
-Chet
Hush........ lol, I love it! I originally thought that I could eyeball mine as well until I got an alignment. I was way off. Like 8 1/2 positive on the driver and 6 something on the passenger. Our cars like 7 degrees positive caster.
I don't know if that's "way off" but I hate it when specs don't match!
Acuratechva
Car: Black Kouki
would any of you trust ebay tention rods? any other then Tein those are obviosly the ****
240DRFT
i have the Tein : the SPL are also very good...and a little cheaper
chmercer
sheesh guys, its pretty easy to match them up to the stock arms. what i did was get a bunch of washers and 2 long bolts and some nuts, and bolted the stock arm onto the aftermarket one. tightened down the adjuster bolts that way. caster is off like maybe a half degree max from stock. its a pretty good way to do it if you cant afford an alignment.
SmithSR
Car: 240sx
If you can't afford an alignment there is a problem
Meantime
Just had mine aligned the other day after correcting my BV tension rods. Like an idiot I didn't bottom both ends out before installing, so I had to take them off and put them back on. Here was my caster results:
Left front - 6.28 degreesRight front - 7.42 degrees
Even though I lined up the rods with the holes, the sides don't necessarily match...as you can see they were over a degree off from one another. Now fixed. Moral of the story: get an alignment.
Quach
Car: 1990 300zx TT
where can i find stiffer tension rod bushings? mine are shot, but i dont wanna replace them with oem, but im not finding anywhere where i can find just the bushings.
SmithSR
Car: 240sx
Energy Suspension, but some say they don't allow axial movement... which causes a binding and shear load of the tension rod, which in turn, cracks the lower control arm. Could it be the culprit? Never seen one in person, and I've seen a lot of modified s13's
veilside180sx
I dig my SPL tension rods. I wouldn't risk it on the ebay arms. The steering precision will outweigh any negatives of ride quality.
Silvia2b
Car: 95 240sx se / 07 G35s cpe / 2009 G37s sedan (rear-ended R.I.P.) / 19 Q50 rs400AWD
http://www.PDM-racing.com , has just bushings and will sell the TC rods with bushings already installed.
