Are 91 cams the same in auto and manual?
Camel
Car: That would be obvious....
Thinking about buying some cams from someone with auto cams, just wondering if they are the same as the manual.
Also, when you do the cam swap, do you use the same shims that were originally in your car or do you have to re-shim?
Thanks.
Camel
btt- Anyone? Not much info on this topic using search. NISTECH - Do you know?
ss240
assuming since you said camS it would be a 91 DOHC... and I believe the auto cams are the same as the manual...
NiSTECH could comfirm this for sure... but I would see no reason for auto and manual cams to be different since it runs of the crank and doesn't really have much to do with the transmission
Camel
That is what i thought. Thanks.
NISTECH - You listening man?
