toledo240 wrote:I wouldn't worry about upgrading injectors unless you go bigger turbo, your stock ones are still efficient enough for 14psi. s15 480's injectors are cheaper than 550's and thats is good enough to run t28's
Not on a T28 ... the injectors are well over their operational duty cycles at 14psi. That's why Nissan upgraded to 480's on the S15's.
If you want a set of new Nismo 555's they are $488 shipped from SPL Parts (
www.splparts.com), you can give me a call sometime this week about them if you'd like. Our number is 1-866-SPL-PART
