wolfgang's G »
https://forums.nicoclub.com/wolfgang-s-g-u222023.html
Sat Jul 13, 2013 12:13 am
For whomever is interested, the problem turned out to be: the nut securing the ball joints had backed out, allowing the lower suspension assembly to become loose and rattle - fortunately, my ball joints were still OK, 'cuz they can only be fixed by replacing the entire A-Arm assembly at $300 per side! I merely had to replace and tighen the nuts using Slotted nuts from a hardware supplier (much like the spindle nut on older vechicles).
There is a flaw in the design of the assembly... Infinity should have used slotted nuts, so that the cotter pin could keep them from turning/back out, once tightened. Instead, they just used regular nuts, and the regular nuts worked themselves loose, down to the cotter pin which is 1/16"-1/8" lower than the nut. ENGINEERING BRAIN-FART! ...had to buy and replace with slotted nuts from a hardware supplier. SLOTTED NUT SIZE is 14mm ID x 1.5mm pitch
