arc induction box?
fitch9014
Car: rocket powered, monkey navigated, salt flat special
i just got one and i'd like to replace the filter as it is oily...i tried to clean it but no good it's gone...just wondering if anyone has one and has had to replace the filter where the best price, fastest delivery is going to be...and if not maybe a ballpark figure on the cost, thanks...
iliketocrash
i think maybe it's supposed to be oily.
fitch9014
iliketocrash wrote:i think maybe it's supposed to be oily.
no, i'm pretty sure it's not supposed to be black oily, i could understand if it were like k&n oily, but it's just dirty...
952FourtyEssex
Car: 95 240SX
That mean that it needs to be washed and re-oiled right?
damesta
projectnissan.com sells them
NeedCAforS13
Car: CA swapped S13 coupe
k&n makes one that drops in there (or so I've heard)... I would just measure the size filter you need and go up to autozone.
fitch9014
NeedCAforS13 wrote:k&n makes one that drops in there (or so I've heard)... I would just measure the size filter you need and go up to autozone.
does the k&n filter oil cause any mass airflow damage? i've heard stories of them fouling maf meters...of course it's stories, i've had a few and never been all that impressed, but, if it fits...thanks for the info
NeedCAforS13
I've heard the same thing, but I don't know where you're going to find a high flow dry filter that's shaped properly to fit in your ARC box without dropping $$$ for a new arc filter. If it fouls up your maf, just clean off the oil with some brake cleaner.
teddy
Car: Saab Turbo and MR2
People have had trouble with them fouling the maf when you use the recharger kit on their filter. People spray too much oil on the filter, and it just all soaks through.
nnkfws333
Car: 2004 Infiniti G35 and a 1989 Nissan 240SX
Or you could reoil the filter and let it dry overnight. I see so many people clean and reoil it only to put it back on and start driving.
rico05
Car: 1992 RMS13 w/ CA18DET
I know that http://www.raretrick.com can also get you the filters, but IIRC they are better than $100. I know the air box new is $325.
fitch9014
NeedCAforS13 wrote:I've heard the same thing, but I don't know where you're going to find a high flow dry filter that's shaped properly to fit in your ARC box without dropping $$$ for a new arc filter. If it fouls up your maf, just clean off the oil with some brake cleaner.
okay, i know this is being picky but wouldn't you want to use like, throttle body cleaner instead ...just saying. i've done some independent research on the subject. first i pulled every air filter off the shelf at work and tried to make one fit. no good. and according to one trip to the only auto store that will continue to put up with me the only air filter that fits is for a '99-04 merc clk kompressor, that's rough dimensions...i think i'll just get an arc, project nissan's got them for about $75 and if that doesn't work rhdjapan quoted me $95 shipped, high i know, but such is the cost of exclusivity, right? god, i'm an idiot!! somebody should ....thanks for the input and help!
