Really? Out of your league?simmode1 wrote:Ok, guys. My Zenki sprung a massive fuel leak and as far as I can tell, it looks like it's leaking from the tank rather than the fuel lines.
I found this write up on the replacement process.http://www.tamparacing.com/for....html
It's kinda out of my league, so I'm curious as to approximately how much this kind of job would cost at a shop. Any ideas, guys?
Yeah, already got somebody holding a used tank for me...OutToWinPAHC wrote:Really about 3 hours of work and a jack. Just get a used tank.
Oh really? It looks like the process seems different between the s13 and s14 models. Are you guys sure it's that easy? It sure as hell didn't look that easy when I was under there. Looked like I was gonna need a lift and possibly remove the subframe, exhaust and half of the driveshaft...Space Monkey wrote:
Changing the tank on a 240sx is easy as pie. a few hoses, 3 bolts and a jack...3 hours if your slow. Super Easy!
HOLY CRAP! That is a PITA!C3Sierra_S2000 wrote:For the S14 you will have to disconnect the driveshaft, disconnect the parking brake cables, drop the exhaust, disconnect fuel pump, disconnect the filler and vent hoses, drop subframe, remove tank straps, drop tank. It sounds like a lot but it really isn't a big deal. I could get it done in an afternoon.
Yay for s13's.OutToWinPAHC wrote:S13 open trap door disconnect wires/hoses. Disconnect fill pipe from body. Put jack under it and disconnect straps and lower. Then reverse the process to install.
Thanks for the input guys, but I really don't have the time or resources to do this myself right now. There's a particular shop I have in mind to do this work. I want them to do it, so I can see if I want to use them for bigger projects in the future. But I just want to get an idea of how much this will cost to have it professionally done. I'm not rich, but I'm not hurting for cash either.Wc240 wrote:it is a lil bit more involved than a 13. but id do it yourself. thats a pretty good labor bill for that. its not as bad as you think, just taking off more stuff
