Approximate rwhp
2jz240sx
Car: 1991 240sx with a sr20det engine swap
What is the approximate rwhp for a 240sx with a sr20det blacktop with a GT28 Turbo running 22 psi and 12 psi with 850cc RC injectors.
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
Well that's difficult to estimate with just the turbo, boost and injectors. I really don't think a t28 is efficient at 22psi.
Supporting mods make all the difference. Head work, cams, exhuast, bottom end condtion.
If i had to take a guess at a stock SR tuned for 22psi on a t28 i would say it hitting about 370-390hp. At 12psi about 240-260hp.
But like i said thats really a shot in the dark. I put down 317 at 14psi with a 2871 .86 on a mustang dyno which reads about 15% less then a dyno jet. So about 340 on a dynojet. The dyno numbers are variable as well.
2jz240sx
I forgot to mention that it has a built bottom end, high performance heads and cams. It is projected to be able to hold up under high horsepower. But like you said it is hard. I am just trying to get a ruff estimate.
