VBitter »
https://forums.nicoclub.com/vbitter-u268075.html
Mon Oct 17, 2016 7:15 pm
I found these CEIKA Type 1M Coilover suspension kit 33 click Bolt-on Custom built & Adjustable on EBAY, but the seller needs help. If someone could post info, we can get them to make them for the newer Rogues if anyone is interested. Here's the message that was sent to me:
Hello,
Thank you for your reply.
We would need the measurements of the following:
- Top plates bolt diameter and distances between bolt centers
- Picture of the top plates showing orientation if camber plates are available.
- Bottom mounts holes diameter, width and spacing
- Strut overall length
- Location and dimensions of brake line/abs/swaybar brackets if there's any.
If you have some pictures of the stock suspensions from you or online then i could take a look and give you the exact list of measurements. But basically it's what is stated above. If you can send us some datas we will let you know after reviewing if we are missing anything.
Looking forward to read you.
Best regards.
Gauthier - CEIKA Team
Let me know!! Thanks.
